I've been learning about AC circuits and they seem pretty straight forward, except when it comes to transformers. I have this circuit and I want to figure out the Voltage and Power at R2, and also the input Power. A note to add is that the inductance of the primary coil and the capacitor are in resonance.
I know there's some mirroring effect going on which can be described as the first circuit in parallel, but whenever I do the calculations and solve for the voltage over R2 I get expressions which does not match with simulations (or reason, such as voltage going to infinity as N goes to 0). If someone could help me with this problem or point me toward some good tutorials/lecture material dealing with these examples I would be very thankful :)
New contributor
Beacon of Wierd is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
    \$\begingroup\$ Please show us all of your work, explain your calculations, and show us your simulation results. \$\endgroup\$ – Elliot Alderson Jan 13 at 1:46
Beacon of Wierd is a new contributor. Be nice, and check out our Code of Conduct.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
