I am having some convergence issue with DC sweep for a CMOS inverter.
To duplicate the exact issue, see the following log as well as the attached netlist files, together with modelcard.nmos and modelcard.pmos
I have tried various suggestions online (such as bypassing .op analysis , using smaller dc sweep step, use .ic initial condition, add parasitic resistance to circuit nodes), but those do not help in my case.
dc sweep circuit analysis of cmos inverter
ngspice run log
[phung@archlinux frequency_trap]$ make test_CMOS_Inverter.net
gnetlist -L ../.. -g spice-noqsi test_CMOS_Inverter.sch -o test_CMOS_Inverter.net
reading specific gafrcLoading schematic [/home/phung/Documents/Grive/Personal/Analog/Active_Inductor/frequency_trap/test_CMOS_Inverter.sch]
[phung@archlinux frequency_trap]$ ngspice test_CMOS_Inverter.net
ngspice-30 : Circuit level simulation program
The U. C. Berkeley CAD Group
Copyright 1985-1994, Regents of the University of California.
Please get your ngspice manual from http://ngspice.sourceforge.net/docs.html
Please file your bug-reports at http://ngspice.sourceforge.net/bugrep.html
Creation Date: Thu Jan 3 04:39:51 UTC 2019
Circuit: * gnetlist -l ../.. -g spice-noqsi -o test_cmos_inverter.net test_cmos_inverter.sch
Doing analysis at TEMP = 25.000000 and TNOM = 27.000000
No. of Data Rows : 1
@m.x1.m1[gds] = 0.000000e+00
@m.x1.m1[gm] = 2.080796e-03
@m.x1.m2[gds] = 5.094415e-03
@m.x1.m2[gm] = 1.145951e-03
cout = 2.997462e+00
v_ip_out#branch = -2.99746e-11
vd#branch = -1.71460e-03
vdd = 3.300000e+00
vin = 1.650000e+00
vin#branch = 0.000000e+00
vout = 2.997462e+00
vs#branch = 1.714603e-03
vss = 0.000000e+00
^Ceference value : 0.00000e+00
Interrupted once . . .
doAnalyses: Too many iterations without convergence
dc simulation interrupted
No. of Data Rows : 100
ngspice 1224 -> listing
 2 : .param supply=3.3v
 3 : .global gnd
 6 : x1 vin vout inv1
 7 : vs vss 0 0v
 8 : vin vin 0 dc {supply/2} ac 1
 9 : vd vdd 0 {supply}
10 : v_ip_out cout vout dc 0v
11 : r1 0 cout 100g
12 : cout 0 cout 1n
14 : .model n1 nmos
15 : .model p1 pmos
16 : .global vdd vss
21 : .subckt inv1 2 1
23 : m2 1 2 vdd vdd p1 l=0.4u w=3u m=25
24 : m1 1 2 vss vss n1 l=1.2u w=3u m=25
26 : .ends
28 : .control
29 : save all @m.x1.m1[gm]
30 : save all @m.x1.m2[gm]
31 : save all @m.x1.m1[gds]
32 : save all @m.x1.m2[gds]
33 : op
34 : print all
35 : dc vin 0 vd 0.1
36 : ac lin 100 1 10g
37 : let gm=(i(v_ip_out))/vin
38 : plot gm
39 : print gm > transconductance_of_cmos_inverter.log
40 : .endc
13 : .options temp=25
41 : .end
ngspice 1225 -> listing expand
23 : m.x1.m2 vout vin vdd vdd p1 l=0.4u w=3u m=25
24 : m.x1.m1 vout vin vss vss n1 l=1.2u w=3u m=25
 7 : vs vss 0 0v
 8 : vin vin 0 dc    1.64999999999999991e+00   ac 1
 9 : vd vdd 0    3.29999999999999982e+00
11 : r1 0 cout 100g
12 : cout 0 cout 1n
14 : .model n1 nmos
15 : .model p1 pmos
26 : .end
ngspice 1226 ->
* gnetlist -L ../.. -g spice-noqsi -o test_CMOS_Inverter.net test_CMOS_Inverter.sch
* SPICE file generated by spice-noqsi version 20170819
* Send requests or bug reports to [email protected]
X1 Vin vout INV1
Vs Vss GND 0V
Vin Vin GND AC 1
Vd Vdd GND 'SUPPLY'
V_IP_out Cout vout DC 0V
R2 GND Vin 100G
R1 GND Cout 100G
Cout GND Cout 1n
.PARAM SUPPLY=3.3v
.options TEMP=25
.IC v(Vin)=1.65 v(Vout)=1.65
.MODEL n1 NMOS
.MODEL p1 PMOS
.GLOBAL Vdd Vss
.INCLUDE CMOS_Inverter.net
.control
*op
print all
dc Vin 0 Vd 0.01
ac lin 100 1 10G
let Gm=(i(v_ip_out))/Vin
plot Gm
print Gm > Transconductance_of_CMOS_inverter.log
.endc
CMOS_Inverter.net
* gnetlist -L ../.. -g spice-noqsi -o CMOS_Inverter.net CMOS_Inverter.sch
.subckt INV1 2 1
M2 1 2 Vdd Vdd P1  l=0.4u w=3u         m=25
M1 1 2 Vss Vss N1  l=1.2u w=3u         m=25
.ENDS
  • \$\begingroup\$ Try to reduce the humongous 100G to 1G, or less (1Meg..100Meg shouldn't interfere too much), maybe add a 1m series resistance to the 1n capacitor. Compared they have a great dynamic range difference that may confuse the matrix solver. Also try some 1m..100m series resistance to the supplies, just for the testing. \$\endgroup\$ Jan 14, 2019 at 8:01
  • \$\begingroup\$ @aconcernedcitizen Capacitances are ignored in Spice DC analysis. \$\endgroup\$
    – Sven B
    Jan 14, 2019 at 10:27
    \$\begingroup\$ @aconcernedcitizen I just read that the convergence issue starts after the OP... The issue is then indeed most likely a numerical one. \$\endgroup\$
    – Sven B
    Jan 14, 2019 at 11:02
    \$\begingroup\$ @aconcernedcitizen the suggestion of reducing 100G to 1Meg for both R1 and R2 does not help \$\endgroup\$
    – kevin
    Jan 14, 2019 at 12:16
    \$\begingroup\$ @SvenB DC Sweep convergence problem solved using this solution \$\endgroup\$
    – kevin
    Jan 16, 2019 at 7:43
