I have a question about an LM741 op amp IC.
I am using the op amp as an comparator (open loop with no feedback), as seen below:
  1. When the op amp output is low, the output voltage is still around 1.2v. Is this normal? Is it because the op amp can't output the full voltage swing in either state (low 0v or high 9v output) due to the op amp's non-ideal properties?
Note, problem remains with load transistor removed from circuit.
  • \$\begingroup\$ what's the "output voltage" in your schematic? \$\endgroup\$ – Marcus Müller Jan 13 '19 at 21:14
  • \$\begingroup\$ Oh sorry, it’s the output voltage from the op amp, pin 6 on the op amp shown in the drawing. I expected the output voltage to be 0v when the op amp output is low, but it remains at 1.2v \$\endgroup\$ – David777 Jan 13 '19 at 21:17
The LM741 is a terrible choice here – not only is it straight from the 1970s, but most importantly, it's not a rail-to-rail opamp – when you read its datasheet, you'll notice that the voltage swing is some 1.5 to 3 V away the positive and negative supply voltages.
Besides from that, the TI datasheet for the LM741 recommends a dual supply of +- 10 V relative to ground – you're not even giving it half of that.
So, it's no use using a LM741 in a single-supply design where you need the opamp's output to venture reliably below 1V.
Get a better opamp. You're looking for something that has rail-to-rail properties, and a minimum supply voltage below your supply voltage. In fact, 9V is a rather uncommon voltage, and maybe a much lower V_cc,min opamp will make your life easier?
I'd recommend perusing TI.com's product tables. There's so much better stuff that can be had for a couple of cents including shipping (arrow.com).
Also note: potentiometers scratch, ring. You really want a capacitor to stabilize that input voltage if you're planning on turning that thing during usage.
  • \$\begingroup\$ Great answer, thank you Marcus. This is the only op amp I have. I will pay more attention to data sheets for selecting op amps. \$\endgroup\$ – David777 Jan 13 '19 at 21:32
    \$\begingroup\$ as said, for five minutes research on TI.com and a few cents including shipping you can get better stuff at arrow.com. There's really no excuse. \$\endgroup\$ – Marcus Müller Jan 13 '19 at 21:55
  • \$\begingroup\$ Yes, I will get some more suitable IC's such as LM311, LM393 or LM 339. \$\endgroup\$ – David777 Jan 13 '19 at 22:05
Yes, it's normal. It's not non-idealities per se, but the internal circuitry in this op-amp is incapable of providing a larger voltage swing.
  • \$\begingroup\$ Thank you, you are correct. This op amp doesn’t suit my application very well. \$\endgroup\$ – David777 Jan 13 '19 at 21:34
