I am trying to double the voltage out from a 1.5V battery using an MCP618 op-amp as a learning experience prior to using the op-amp to amplify the output from a set of strain gauges set up in a Wheatstone bridge.
However, to check that I wasn't doing something totally dumb, I wanted to start from a circuit with a unity gain. That circuit is as below.
The voltage measured by VM1 equaled zero, which makes sense to me. If the op-amp is trying to make the difference from V+ to V- equal, then V+ should equal the output. Hence, I then tried to make this into a voltage doubling circuit, as shown below.
Now, when I measure from the output to the input, I would anticipate reading a doubled voltage. Instead, I read a potential difference of ~1.5 V (i.e., the input is 1.5 V higher than the output). By measuring from the output to the negative terminal of the battery, the output from the op amp is 23 mV from zero, relative to that negative terminal.
What am I screwing up here?
---------------------------EDIT 1/15--------------------------------
I've redone the circuit as suggested in the initial answers (or so I believe), but am still seeing the same behavior as before. The circuit I'm now using is as follows:
In short, when I run this, I see a potential difference of 20 mV between nodes A and B on the diagram, which doesn't change when I disconnect the 1.5 V source. Any help is appreciated.
EDIT #2 (1/15): Added the 10k from battery to non-inverting input, and checked for shorts and such. No change in behavior, even with a new chip. I did notice that there was a current spike (1 amp!) on chip's power supply when I turned it on after plugging the new one in (which made the chip nice and toasty), so I added a 15k resistor between the power supply and the Vss pin as well. Upon putting a new chip in place with this 15k resistor on the Vss pin, it didn't give me a current spike, but it did give me still the same behavior as before. Circuit now appears as follows:
ERROR FOUND (between chair and breadboard): supply voltage to op amp was connected to Vss instead of Vdd. Circuit (less the resistor between +5V and Vdd) now exhibits the desired behavior.
    \$\begingroup\$ no ground ref. for either input \$\endgroup\$ Jan 15, 2019 at 3:25
You need to connect the battery (-) to GND in the first diagram, and the battery (+) to ground in the second.
But before you do that, increase those feedback resistors by several orders of magnitude. 10K to 100K for the MCP618. You must not exceed the absolute maximum 2mA input current, and the second circuit will pass around 7mA into the inverting input until the output catches up with it. The first circuit also could pass a significant current under certain conditions (with power supply voltage = 0), so you can add 10K in series with the non-inverting input (on the output of the batter). Such relatively high value resistors will protect the op-amp inputs and from latch-up.
You don't need (and shouldn't have) a resistor in the supply rail. A bypass capacitor of 100nF or so across the supply rails would be good.
  • \$\begingroup\$ Add another 10K from the battery to the non-inverting input (for protection), check your wiring carefully, and then try another (fresh) chip if everything is correct. \$\endgroup\$ Jan 15, 2019 at 16:03
  • \$\begingroup\$ Added the 10k from battery to non-inverting input, and checked for shorts and such. No change in behavior, even with a new chip. I did notice that there was a current spike (1 amp!) on chip's power supply when I turned it on after plugging the new one in (which made the chip nice and toasty), so I added a 15k resistor between the power supply and the Vss pin as well. Upon putting a new chip in place with this 15k resistor on the Vss pin, it didn't give me a current spike, but it did give me still the same behavior as before. \$\endgroup\$
    – Marius
    Jan 15, 2019 at 16:29
  • \$\begingroup\$ Sounds like you're killing the chips by a wiring error of some kind (supply polarity?). That chip draws about 20uA. \$\endgroup\$ Jan 15, 2019 at 16:33
    \$\begingroup\$ Ugh -- you got it. I had read somewhere that Vss meant "source", when, in fact, it is synonymous with "ground". Everything presently works as expected. \$\endgroup\$
    – Marius
    Jan 15, 2019 at 16:45
    \$\begingroup\$ Thanks for closing the loop. Vss does refer to source- the "source" pin of an N-channel MOSFET, which is connected to ground in this case, and typically the most negative voltage in the circuit. \$\endgroup\$ Jan 15, 2019 at 17:52
The input sides of both circuits needs a ground reference, and you need to read the output with reference to ground.
In both circuits, to get the behavior you want, you need to ground the '-' terminal of the battery.
The only path for current thru R4 is thru the voltmeter (10 Meg ohm) and the input ESD diodes of the OpAmp.
Thus that 1.5 volts is imposed across the 2 input pins of the OpAmp, which in a controlled negative-feedback circuit will be low low MICROVOLTS.
Regulation, servoing, feedback ---- is being prevented.
