I have a small DC motor being driven by a controller which supplies +6V/-6V to the motor to control its speed and direction (elliptical machine resistance control motor). The issue is that 6Vs is not provide enough speed/power from the motor, but if I drive the motor with a 9V or 12V battery it works sufficiently. The controller determines the position of the mechanism with a potentiometer and changes the driving voltage accordingly until the correct position is reached. What I would like to do is double the voltage being supplied to the motor (to +12V/-12V), while leaving the rest of the system intact. I have been trying to research simple cheap boost converters, but I cannot figure out if these devices can take a varying +/- input voltage and output the corresponding +/- voltage with double the amplitude. Thanks in advance for any insight anyone can provide.
  • \$\begingroup\$ Unless you define the specs for input and load power, temp rise, peak load current, DCR, driver design , your question is unanswerable. \$\endgroup\$ – Sunnyskyguy EE75 Jan 15 at 15:57
  • \$\begingroup\$ Maybe I am really showing my limited electronics understanding here, but I would not think this would all be necessary for a small low power DC circuit. I am sure the motor is drawing only a few hundred milliamps at -6V/+6V. Is there not a kind of boost converter that could simple multiply (1.5X, 2X) my positivite and negative input voltages, while providing a current up to perhaps 1A? Even a boost device using an external 12VDC or 120VAC power supply would be acceptable. If it weren't for the varying -/+ input voltage I would have thought a standard hobby grade boost converter would work. \$\endgroup\$ – jslade11 Jan 15 at 18:57
  • \$\begingroup\$ What is the motor DCR? \$\endgroup\$ – Sunnyskyguy EE75 Jan 15 at 18:57
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
