I wrote a program for a '11' sequence detector to be implemented by both Moore and Mealy machine. The problem statement is for z to be asserted high after x has been high for 2 cycles. I've attached my implementation below, but what I am seeing is that for both FSMs, z is asserted one cycle too early. Can anyone spot the error in my FSM or code? I would really appreciate any input on what I may be doing wrong! Thanks
FSM:
Systemverilog code:
Moore:
module moore_fsm
(input bit clk, reset, x,
  output bit z);
  typedef enum bit [1:0] {A, B, C} states;
  states current_state, next_state;
  always_ff @(posedge clk, negedge reset) begin
  if (~reset)
  current_state <= A;
  else current_state <= next_state;
  end
  always_comb begin
  case (current_state)
  A:begin
        z=0;
        if (x==0) begin
      next_state = A;
        end
        else begin
        next_state = B;
        end
        end
  B:  begin
        z=0;
        if (x==1) begin
        next_state = C;
        end
        else begin
        next_state = A;
        end
        end
  C: begin
      z=1;
     if (x==1) begin
      next_state = C;
      end
      else begin
     next_state = A;
      end
      end
  endcase
  end
  endmodule:moore_fsm
Mealy:
module mealy_fsm
  output bit z);
   typedef enum bit {A, B} states;
  if (~reset)
  current_state <= A;
  end
  always_comb
  begin
  A: if (x==1) begin
      next_state = B;
        z=0;
        end
        else begin
        next_state = A;
        z=0;
        end
    B: if (x==1) begin
        next_state = B;
        z=1;
        end
        else begin
        next_state = A;
        z=0;
        end
  endcase
  end
endmodule:mealy_fsm
Testbench
module moore_mealy ();
bit clk, reset, x, moore_z, mealy_z;
moore_fsm dut1 (clk, reset, x, moore_z);
mealy_fsm dut2 (clk, reset, x, mealy_z);
initial begin
reset = 1;
 #1 reset = 0;
 #1 reset = 1;
 #5 x=0;
 #5 x=1;
 #28 x=0;
 #20 x=1;
 #10 x=0;
 #10 x=1;
 #150 $finish;
end
always begin
 #5 clk = ~clk;
end
endmodule:moore_mealy
Output Waveform:
In your Moore machine you set the 'z' in the combinatorial section. At the same time as you set the state to C. Thus the two coincide. To get z high after two bits have been detected (thus after the state C) you must move the assignment into the clocked section:
z <= (state==C) ? 1'b1 : 1'b0;
// or even shorter:
z <= (state==C);
Your Mealy machine is a problem. The definition of Mealy brings with it that the input defines the output directly. Thus Mealy dictates that you must use a combinatorial statement of the type:
assign z = some_condition_with_state && x; // or without assign in your always_comb section
The 'directly' means you can't really set 'z' after x has been high for two clocks as by that time it may have gone low again.
One last tip: Don't use variables like 'z' and 'x' as they are too easily confused with 1'bx and 1'bz.
Let's discuss the Moore implementation. You set the initial state to A with the condition that x has to be 1 on a rising clock edge for the transition to state B. Now have a look at your waveforms. the current state is A, then x goes high. With the next rising clock edge you switch to state B, so far so good. Now we await another rising clock edge before we change to state C where z is set to be high. Again we check the waveform and see that that's exactly what happens.
So the assignment of z does not happen after 2 clock cycles as you expect but after the 2nd rising edge of the clock.
This should help to solve the Mealy on your own.
