I could not find out what type of connector this is. It has a width of approximately 10mm, 0.5mm pitch, and 30 pins. I assume it is some kind of diagnostic port. It is part of a mobile device with OMAP4470 processor. Any help would be appreciated. Many thanks!
  • \$\begingroup\$ What device is this connected to? (please edit your question with these details) \$\endgroup\$ – KingDuken Jan 15 '19 at 17:11
  • \$\begingroup\$ Connectors ate usually classified by pitch (distance between two pins). This information would be more relevant than the total width. \$\endgroup\$ – dim Jan 15 '19 at 17:26
  • \$\begingroup\$ It looks like a custom JST connector with 30 dual row centre contacts and 30 dual row side contacts perhaps for high speed interleaved grounds. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jan 15 '19 at 17:36
  • \$\begingroup\$ There are a lot of similar-looking connectors. Measure the pitch (use a number of pins and divide by the number of spaces) and look at things like so-called mezzanine connectors. \$\endgroup\$ – Spehro Pefhany Jan 15 '19 at 17:49
  • \$\begingroup\$ I might have found it: digikey.com/en/product-highlight/h/hirose/df12-series \$\endgroup\$ – garth Jan 15 '19 at 17:53
Take a look at JST part 30R-JMCS-G-B-TF(NSA) Mezzanine Connector Pitch matches.
| improve this answer | |
