I have a lightning earphones, Sennheiser ambeo smart headset. https://en-us.sennheiser.com/finalstop
The cables are yellowing, and I wanted to replace them, also I got tired of using this on my Iphone only, I wanted this to work with most modern devices with USB-C..
So I thought, could I just replace the whole thing with a 8-core cable with a usb-c connector?
If no, why. If yes, what most likely will fail? I feel like as long as I can connect the wires properly, then there would be no problem.
closed as off-topic by Elliot Alderson, Voltage Spike, Dwayne Reid, Edgar Brown, RoyC Jan 19 at 15:26
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – Elliot Alderson, Voltage Spike, Dwayne Reid, Edgar Brown, RoyC
If this question can be reworded to fit the rules in the help center, please edit the question.
The simple answer is no.
Lightning sends digital data to the headphones which contain a digital to analog converter that makes something your ears can hear. The headphones also negotiate power from the phone to run them.
USB C can have analog outputs and/or digital outputs. These would not be compatible with the digital format of Lightning. Also, power negotiation is completely different.
  • \$\begingroup\$ but I could I think at least change the cables? \$\endgroup\$ – Joey Hipolito Jan 16 at 19:07
    \$\begingroup\$ @JoeyHipolito That is going to depend on how good your soldering skills are, if you can open the headphones without destroying them, and if a similar cable is available. Most cable for headphones is super fine for good flexibility and that makes it awful to solder. My vote for this case is; if it ain't broke, don't fix it. \$\endgroup\$ – vini_i Jan 16 at 19:12
