14
I am modeling the fine behavior of interacting oscillatory circuits. I have looked up a couple of methods for measuring inductance. I believe I am following the procedure faithfully, but the values I obtain aren't as precise as I expect. This is, in principle, an elementary question, but ideally I'd like precision of 1% or less and I don't believe I am attaining it with the methods I can find. I have a Tektronix 1001B oscilloscope and a pretty standard signal generator.
First: Is a precision of 1% with this equipment unrealistic?
If not, I have followed the procedure for measuring inductance with a sinewave here: https://meettechniek.info/passive/inductance.html (I also tried the method where you tune the frequency until the inductor voltage is half the total voltage).
I measure across two inductors in series; as a sanity check I also did both inductors separately. L1 is the kind of inductor that looks like a resistor (see the green thing in the photo below); Lcoil is a coiled inductor (see below). The nominal values are L1=220 uH and Lcoil=100 uH, so I expect a total of roughly Ltot=320 uH. All measurements are with f=95kHz because that is the frequency of operation.
  • R_s=100 Ohm gives Ltot=290, L1=174, and Lcoil=122 (L1+Lcoil=296)
  • R_s=56 Ohm gives Ltot=259, L1=174, and Lcoil=98 (L1+Lcoil=272)
Are these the best numbers that I can expect? The coil value changes by over 20%, and the total value varies by ~10%. I do not have an electronics background, so if there are some basic intuitive principles I am overlooking, please let me know!
inductors
Edit: I add a screencap of one of the calculations, which provides the values of the inductance and the inductor resistance. calculation
  • \$\begingroup\$ Buy an expensive LCR meter, or just buy a few very accurate inductors as a reference, then do A vs. B comparisons. With a signal generator and o-scope, you need known accurate references to judge the unknown values better. We cannot recommend manufactures or sources, as that violates site rules. \$\endgroup\$
    – user105652
    Jan 16, 2019 at 21:01
  • \$\begingroup\$ Were you calculating the ESR of the inductors as well? How did those numbers look? \$\endgroup\$ Jan 16, 2019 at 21:10
  • \$\begingroup\$ @ElliotAlderson I added a picture of the calculation for the total inductance for R_s=56. The ESR is sane for this calculation, but the value varies a lot in some calculations, which is also a source of unease. \$\endgroup\$
    – KBL
    Jan 16, 2019 at 21:27
15
The method you use is very error sensitive, ESR can be an issue but also determining the exact voltage ratios isn't easy.
I would use LC-parallel resonance:
\$F_c=\frac 1 {2\pi\sqrt{LC}}\$
Get a 1% (or better) accurate capacitor. If you do not have such a capacitor then just forget about the whole thing, you will not get the 1% accuracy.
Use a circuit like this:
If you have a rough value for Lx then use the formula above to determine the resonance frequency in combination with the accurate capacitor C_1%.
You should aim for a frequency that the signal generator can easily generate, for example 1 MHz. Set the generator output voltage a couple of volts, the exact value does not matter because we want to determine the resonance frequency.
Vary the frequency of the generator and on the oscilloscope keep an eye on the signal amplitude. The frequency where the amplitude is the largest, that is the resonance frequency. Then use that frequency and the value of C_1% to determine the value of Lx? using the formula above.
If the signal generator is not very accurate (if it is an analog signal generator) then measure the frequency using your oscilloscope. You need a better than 0.01% accurate value for the frequency otherwise you cannot get the 1% overall accuracy. Your oscilloscope is a digital one so it can measure frequencies with more enough accuracy.
    \$\begingroup\$ frequency follows sqrt(LC) so to get 1% inductance you need at-least 0.01% accurate frequency measurement. \$\endgroup\$ Jan 17, 2019 at 1:50
    \$\begingroup\$ If you think it is necessary to measure the frequency to 0.01%, you had better take account of the resistance of the inductor on the exact position of the peak response for a damped oscillator. \$\endgroup\$
    – alephzero
    Jan 17, 2019 at 11:26
    \$\begingroup\$ I don't see why you should require 0.01% accuracy for frequency. Inductance should be proportional to 1/(F^2*C); indicating that about 0.5% should be enough. (Obviously with some extra margin since there are two error sources.) \$\endgroup\$ Jan 17, 2019 at 13:55
    \$\begingroup\$ Be aware that for non-ideal inductors (of which this is one), inductance is a function of frequency! Reasons include the frequency response of the core material, and the presence of eddy currents, among others. You should choose a capacitor that approximately places the resonant frequency near your frequency of interest. So, 95 kHz rather than 1 MHz. \$\endgroup\$
    – jbay
    Jan 17, 2019 at 16:53
    \$\begingroup\$ Also, beware of added inductance from the wiring in the rest of your circuit. Your breadboard wiring or PCB traces will act as additional inductances. If you care about the inductance of the inductor (rather than the inductance of the circuit) then do your best to keep those to a minimum, at least by using the shortest possible wires. The inductor you are testing doesn't look like it has a very large inductance. \$\endgroup\$
    – jbay
    Jan 17, 2019 at 17:03
Sunnyskyguy outlines an excellent method. Accuracy does depend on the resonating capacitor error. The other error term is frequency: the Tek 1001B's crystal-controlled timebase should make frequency measurements accurate.
It is worthwhile to outline the alternate test configuration: series LC. You can do this one with function generator + oscilloscope. Function generator outputs a sine wave of decent amplitude:
Adjust function generator frequency looking for a dip of amplitude on the oscilloscope. The depth of the dip gives an indication of inductor quality Q. If your function generator sine wave is low distortion, you can see if non-linearities in the inductor cause harmonics to be observable at the dip-frequency. Harmonics may also be caused by function generator distortion.
\$ L={{1} \over {(2\pi f)^2 C_{test}}} \$
This method has the advantage that oscilloscope probe capacitance doesn't come into play. The path from function generator to test fixture should be as short as possible. From test fixture to oscilloscope can be longer (use a 1x probe).
Many function generators have an accurate internal 50 ohm source resistance. If not, you might attach a 50 ohm attenuator, to establish a solid 50 ohm source resistance. At LC series resonant frequency, you have a voltage divider between function generator's \$ R_{internal} \$ and test-inductor's internal resistance. The dip amplitude oscilloscope voltage allows a calculation of inductor's resistance. Use the two-resistor voltage divider calculation to find it:
\$ R_{inductor} = {50{V_{dip}} \over {V_{open-cct}- V_{dip}}} \$
Disregard this old answer and better to follow preferred method. https://www.testandmeasurementtips.com/how-to-measure-inductance/ enter image description here
You can use series or parallel resonance depending on what impedance you choose at resonance and what Q you expect from either mode. Here 100 kHz is ~ 100 ohms and Q of 30 dB implies 0.1 ohm for DCR.
This can be limited by your driver GBW product. The 300 ohm (1+f) / GBW = Rout unless current limited.
Enter image description here
Here I chose 10 nF film due to a very low ESR. But I needed to buffer with output impedance lower than the DCR of the coil, if I want to measure that. The amplification is the Q or impedance ratio of the signal.
Here both L and DCR are found by rating series C and self winding capacitance from the notch SRF at 1 MHz. Your mileage will vary.
The 5K decouples potential Cin from output resonance with low gain high f NFB.
Usually you want to test it in the frequency region it will be used. Then decide if you want to add DC bias current and AC couple the signal to isolate from your DC power supply.
Normally RLC meters use a constant current sine wave at 1 kHz up to 1 MHz. Then measure the voltage and phase to compute RLC.
  • \$\begingroup\$ What's the use of resistor 5k? \$\endgroup\$
    – Unknown123
    Apr 1, 2022 at 8:06
  • \$\begingroup\$ To decouple Cin from output. \$\endgroup\$ Apr 1, 2022 at 14:22
  • \$\begingroup\$ Does it need to be 5k? How to estimate the range of it? \$\endgroup\$
    – Unknown123
    Apr 1, 2022 at 14:29
    \$\begingroup\$ No Since Ro is around 220 ohms open loop anything much larger but not so it causes Iin*(Rfb-Rs-) =Vio offset \$\endgroup\$ Apr 1, 2022 at 14:40
