This may be a weird question but for a BJT, we have
\$I_S\$ is the reverse saturation current and \$I_C\$ is the collector current which flows through all three parts of the BJT.
Now my question is, \$I_S\$ should also flow through all three parts of the BJT, so can't we just add/subtract \$I_S\$ from \$I_C\$ via KCL? Is that where the -1 comes from?.
    \$\begingroup\$ -1 is there to make the Ic zero when Vbe is zero. \$\endgroup\$ – user1245 Jan 16 '19 at 22:56
  • \$\begingroup\$ \$I_S\$ is a property of the transistor, not a physical current that actually flows through it. The \$I_S\$ in that equation is close to the reverse saturation current of the base-emitter junction, but the equation is off by a factor of \$\beta\$. \$\endgroup\$ – TimWescott Jan 16 '19 at 23:26
    \$\begingroup\$ I discuss it here and here. \$\endgroup\$ – jonk Jan 17 '19 at 3:06
