I'm using a TI micro controller TM4C1230C3PM to flash a .bin using JTAG and openOCD .i have a board with tag connection tc2050 , I have everything connected but when i open the command window of openOCD it wont come up I guess i need a specific library or file to read that micro controller right ? with this setup how can I get it to work ?
  • \$\begingroup\$ You'll at minimum need appropriate command line options, possibly some custom tcl. This is pretty close to a request for custom code or off-site resources; generally you should do a web search for this kind of thing not ask here. As for "if it is possible" it is if either 1) the information necessary is published or 2) someone with non-public information (such as the vendor themselves) contributed support to OpenOCD... but you probably wanted to know how to do it rather than only if it is "possible". \$\endgroup\$ – Chris Stratton Jan 17 at 4:17
