what would be the total inductance of this circuit? https://i.stack.imgur.com/gZHEB.png
    \$\begingroup\$ 'Parallel aiding inductors' = transformer? \$\endgroup\$ – Chu Jan 17 at 9:19
As mentioned by Chu, \$L_1\$ and \$L_4\$ are coupled in your schematics. With defining the coupling as \$M = M_{34}\$, the resulting inductance becomes
\$L = \frac{(L_1+L_2) (L_3+L_4) - M^2}{(L_1+L_2+L_3+L_4) - 2 M}\$
In case they are not coupled (not forming a transformer) we set \$M = 0\$ and get the equation from Joe Mac.
Inductors add just like resistors. So combine the inductors in series to get just 2 inductors in parallel. Then add those two parallel inductors by adding together their reciprocals.
Edit: Then take the reciprocal of that answer. I forgot about this last part. Very important.
\$\frac{(L_{1}+L_{2})(L_{3}+L{4})}{L_{1}+L_{2}+L_{3}+L_{4}}\$
Formula for calculating inductors in parallel is the following:
\$ \frac{1}{L_{total}} = \sum\limits_{n = 1}^{N}\,\frac{1}{L_{n}} = \frac{1}{L_{1}}+\frac{1}{L_{2}}\,...+\frac{1}{L_{N}}\$
Formula for calculating inductors in series:
\$ L_{total} = \sum\limits_{n = 1}^{N}{L_{n}} = L_{1}+L_{2}\,...+ \,{L_{N}}\$
    \$\begingroup\$ Your equation should be1/ /(L1+L2)+/(L3+L4). You are taking the reciprocal of the reciprocals. Do you know Mathjax or LaTex or any markup language? \$\endgroup\$ – Sparky256 Jan 17 at 6:54
  • \$\begingroup\$ You’re right. I forgot about the last reciprocal. \$\endgroup\$ – Joe Mac Jan 17 at 8:11
    \$\begingroup\$ L1 and L4 form a transformer. \$\endgroup\$ – Chu Jan 17 at 9:07
