Please Help with connector identification
Can anyone help me identify this connector type?
I is 2 pin, pitch I think is 0.8mm (I measure it to be 1mm between the outer part of the pins, I do not have the tools for more accurate measurment) From side to side it is 3mm, and 1mm in height. I initially thought it was a type of JST, but after scouring the internet I have not found any matches. Not for JST or Molex or any other brand.
If anyone could help me identify it, I would greatly appreciate it.
    \$\begingroup\$ why did you post a picture of five connectors viewed from a distance instead of a closeup of one connector? \$\endgroup\$ – jsotola Jan 18 at 7:05
  • \$\begingroup\$ @jsotola Perhaps the OP "borrowed" the image from elsewhere... \$\endgroup\$ – Solar Mike Jan 18 at 7:29
  • \$\begingroup\$ Yep. @jsotola is right. Tried taking a picture myself, but could not get a good one And thought the other connectors in the picture could help by adding other angles. \$\endgroup\$ – Flaffarium Jan 18 at 8:05
  • \$\begingroup\$ Looks like a wire to board. Similar to the pico-EZmate from Molex, However I was not able to ID the exact part. Here is a link to the EZmate data sheet. I believe this is similar. literature.molex.com/SQLImages/kelmscott/Molex/PDF_Images/… \$\endgroup\$ – Robert Fay Jan 28 at 14:45
