Some circuits have parallel bars on their inductor symbols such as:
Enter image description here
Does that mean the inductor is wound around a magnetic core instead of air? Is that how a differential choke is represented?
Typically yes. The bar is used to indicate some form of ferrous core.
https://www.conceptdraw.com/How-To-Guide/inductors-symbols
| improve this answer | |
A solid bar indicates a ferrous core (core made of a ferrous metal, such as iron).
A dashed bar indicates a ferrite core.
  • \$\begingroup\$ ferrous core never heard of it. did you mean fameous? \$\endgroup\$ – cm64 Jan 18 '19 at 20:40
  • \$\begingroup\$ @cm64 What Electron means is a core made of a ferrous metal, such as iron or steel. \$\endgroup\$ – Hearth Jan 18 '19 at 20:41
  • \$\begingroup\$ yes.. iron or steel based core \$\endgroup\$ – Satish Singupuram Jan 18 '19 at 20:42
    \$\begingroup\$ yes.. air core colis will have much more less inductance when compared to iron or ferrite core inductors. \$\endgroup\$ – Satish Singupuram Jan 18 '19 at 20:49
    \$\begingroup\$ "Ferrous", made of ferrum, chemical symbol Fe, latin for iron. \$\endgroup\$ – Transistor Jan 18 '19 at 20:53
I see this convention for ferrites such as in the filter you show, tho I can't seem to find an official source indicating this is an official standard of some kind.
Well, IEEE Std 315 specifies this symbol for an inductor with a "magnetic core":
inductor with core, symbol from IEEE Std 315
The standard doesn't show any symbols with a single bar, at least as far as I can see.
  • \$\begingroup\$ When I was a boy, British laminated FeSi cores had three lines; ferrite cores were a single dashed or sometimes dotted line. \$\endgroup\$ – Michael Harvey Jan 19 '19 at 11:58
  • \$\begingroup\$ @MichaelHarvey Yes, I have also seen many variations over the years. I just wanted to point out that there really is a standard way of drawing these things. \$\endgroup\$ – Elliot Alderson Jan 19 '19 at 12:02
