Need help identifying this connector. I am actually looking to purchase a 6 (2x3) position connector of the same kind, so need help with type and where to buy (Mouser, etc).
This is from an IBM server (USB front connector). I want to build one such cable, but with 6 positions.
connector photo 1
connector photo 2
connector photo 3
connector photo 4
Any help appreciated!
  • \$\begingroup\$ Good luck ibselectronics.com/mechanical/connectors otherwise use a 2 x 3 std header socket and add an orientation key and lock. \$\endgroup\$
    – D.A.S.
    Commented Jan 19, 2019 at 3:21
  • \$\begingroup\$ take pictures without anything behind the plug ... your camera is focusing on your fingers and on the electronic components in the background .............. is there anything printed on the connector or on the plug that the connector plugs into? \$\endgroup\$
    – jsotola
    Commented Jan 19, 2019 at 3:26
    \$\begingroup\$ I am guessing 2.54mm x 2.54mm " Product > Housing,Wafer and Terminal > PV slim type board to wire, keyed, with locking ears \$\endgroup\$
    – D.A.S.
    Commented Jan 19, 2019 at 3:28
  • \$\begingroup\$ @SunnyskyguyEE75 Do you have a link to the "keyed, with locking ears"? \$\endgroup\$
    – Molasar
    Commented Jan 19, 2019 at 4:09
  • \$\begingroup\$ not a chance, good luck , do you have any dimensions \$\endgroup\$
    – D.A.S.
    Commented Jan 19, 2019 at 4:10
