I want to write bootloader for avr atmega328p in C language. I want to perfom a page erase:
So I have to write the address of the z pointer. // Don't know how to implement in c code; Then make SPMEN AND PGERS bits high. // SPMCSR = (1 << SPMEN) | (1 << PGERS); Then execute SPM instruction within the next 4 clock cycles // Don't know code;
My 1st question is how do I access the Z-register in order to write the address of the page to be erased, Like I have been able to access the SPMCSR register and set the SPMEN and PGERS bits. something like ZPOINTER = 0x00FFEE;
My second question is that, in the datasheet it states that in order to erase the page at a certain address you have to SET the SPMEN and the PGERS bits, then you execute an SPM instruction within the next 4 clock cycles. How do I execute the SPM instruction after setting those aforementioned bits in C code?
Help will be highly appreciated. Thanks. And I throughly searched for similar info on the internet and came with nothing.
    \$\begingroup\$ You may need to use in line assembly for this \$\endgroup\$ Jan 22, 2019 at 17:34
  • \$\begingroup\$ @alex.forencich are you saying its impossible to implement in C? \$\endgroup\$
    – tmoeti
    Jan 22, 2019 at 18:12
  • \$\begingroup\$ Look at AVR109 source code. It has everything you need. I used it with an ATmega8, but implementation for a 328p should not be much different. \$\endgroup\$
    – filo
    Jan 22, 2019 at 18:26
  • \$\begingroup\$ @filo Thanks for the referral to AVR109 source code. \$\endgroup\$
    – tmoeti
    Jan 22, 2019 at 18:56
    \$\begingroup\$ @ChrisStratton Thanks, my date with AVR109 source code is coming on well now. \$\endgroup\$
    – tmoeti
    Jan 22, 2019 at 22:39
Here's a way to do it in GCC using asm(). The rest of the bootloader was in C except for enabling and disabling interrupts.
while (NVM_STATUS & NVM_NVMBUSY_bm) ;
NVM_CMD = NVM_CMD_LOAD_FLASH_BUFFER_gc;
// load bytes into page buffer
p = flash_RAM_buffer;
for(ix = 0; ix < 512; ix+=2) {
    asm("ld r0, %a0+":: "z" (p) : "r0");
    asm("ld r1, Z"::: "r1");    // load R0:R1 from flash_RAM_buffer
    asm("movw r30, %0":: "w" (ix) : "r30","r31");   // load Z with ix;
    asm("spm"::);               // not change protected
    asm("clr r1"::);
    p += 2;
asm("ldi r30, 0" ::: "r30");        // low byte of flash address (ignored)
asm("mov r31, %0" :: "r" (curr_flash_address.uval8.ML) : "r31");
asm("out __RAMPZ__, %0" :: "r" (curr_flash_address.uval8.MH));
NVM_CMD = NVM_CMD_ERASE_WRITE_APP_PAGE_gc;
asm("cli"::);
CPU_CCP = CCP_SPM_gc;    // set change control register to enable
asm("spm"::);
asm("clr r1"::: "r1");
asm("sei"::);
curr_flash_address is a union that allows accessing it as 32, 16 or 8 bit variable.
  • \$\begingroup\$ I can't really can't understand assembler, but I am studying AVR109 source code, I think it will sort me out. Thanks for the effort though, highly appreciated. \$\endgroup\$
    – tmoeti
    Jan 22, 2019 at 22:41
  • \$\begingroup\$ You're going to have to use assembler since the register setup is quite specific to write xMega flash memory. R0 and R1 need to be loaded with a word and the Z register needs to have the destination flash address before executing the SPM instruction. That can't be done in C alone. The GCC asm() extension is needed. \$\endgroup\$
    – Warren
    Feb 3, 2019 at 1:05
