Using TI's "power designer", I've taken their 33630A and designed it for a 5v output. My actual circuit has a slightly different value for the divider to raise the voltage up to about 5.2v, otherwise it matches this design:
TI circuit designer
..and here's my design. I've reviewed it a few times.
my circuit
My circuit, and the PCB from it, are on easyeda. After assembling the circuit, my output is right around 1 volt and the chip is overheating. I can't figure out why! I've checked for short circuits, and I've done in-circuit tests to ensure the passives are approximately correct.
As a wanna-be-EE, I don't know where to go next. I have a low-end 'scope and a high-end meter. I'm not using this attached to anything (e.g., it isn't actually connected to a Raspberry Pi), and I'm supplying it with 12-16v. I also removed LED1 so I could rule that part of the circuit out.
    \$\begingroup\$ Unrelated to anything, that "pokitmeter" thing looks like a handy thing for hobbyists dipping their toes into EE. Thanks for inadvertently bringing it to my attention. \$\endgroup\$ – Hearth Jan 22 '19 at 17:41
This turned out to be the answer for this specific problem: Double-check that the pad really is soldered down. All kinds of Bad Things could happen without that analog reference being where it belongs.
Going out one layer; when you're working with a prototype you can't assume that a problem is either a design issue (anywhere, schematic or PCB in this case) or an assembly issue. You have to check both. With assembly issues, you have to check everything -- it's easy to get a soldered connection wrong and have it look right. After doing it for a while you come to be an expert at noticing the subtle hints, but it doesn't come quickly. Any soldered connection that's hidden (like a BGA, or those thermal pads) is especially difficult. It's not uncommon for circuit board houses to x-ray boards to verify that all balls on a part are soldered, and that complete coverage between chip pad and PCB has been attained.
| improve this answer | |
You appear to be using a nice beefy inductor, so you've avoided that common noob mistake.
But layout is important for these switchers and yours doesn't much resemble the LMR33630EVM - particularly the trace between the IC and inductor, and inductor & output filter caps (which should all be short & fat).
Similarly, your input caps are too "far away" from the IC - in particular look at the path between pin-1 and the ground pins on those caps - it goes all the way around the edge of your board. Lots of vias would probably help a bit here, but rearranging things to bring them physically closer together with more direct routing would help more.
  • \$\begingroup\$ Thanks. I originally had one that was very close to the spec sheet's pattern but was part of a larger circuit. This was my simplified board to see if I could get it working in isolation. While I wouldn't expect it to be perfect, I wouldn't expect it to outright fail like this. \$\endgroup\$ – tedder42 Jan 22 '19 at 17:26
    \$\begingroup\$ I agree with this, the OP should look at the switch node on a scope to see what's going on. Also could get closer to 5.2V output with 150K and 35.7K divider resistors. (Can find optimal divider resistors and output tolerance range at syncbuck.com ) \$\endgroup\$ – John D Jan 22 '19 at 17:26
    \$\begingroup\$ Also double-check that the pad really is soldered down. All kinds of Bad Things could happen without that analog reference being where it belongs. \$\endgroup\$ – TimWescott Jan 22 '19 at 17:33
  • \$\begingroup\$ thanks all. I'll look at the SW pin and also make up another PCB in the next 24 hours; AGND could very well be the culprit, as I've desoldered and resoldered the 33630 chip on this PCB. If AGND was floating would that explain the chip overheating too? \$\endgroup\$ – tedder42 Jan 22 '19 at 19:05
    \$\begingroup\$ the problem was definitely AGND. Now that my second try is working, I see the switch node going from 0-2V and the inductor is bouncing about 0-8v. So I definitely need to rearrange, but ultimately @TimWescott is correct (please post an answer..). \$\endgroup\$ – tedder42 Jan 23 '19 at 5:27
