I am looking for a DAC design wıth NMOS and PMOS transistors as a part of a project, most of the DAC circuits that I found were builted with R-2R or with capacitors. But I need a design with MOS transistor since the porject will be implemented on Cadence and space consideration is important. DAC will be used both in 8-bit SAR ADC and in smooting filter. Sample block diagram of the project is given below, ı could not find appropriate design for DAC. Any help will be appreciated, thanks in advance. enter image description here
    \$\begingroup\$ This question is very broad. DAC designs are often proprietary, meaning owned by the company that designed it. You should have a look in literature (IEEE journals etc.) to see how CMOS DACs are generally made. Do you have any experience in designing analog circuits? Most CMOS processes not only have MOS transistors but also resistors. You sound inexperienced in the field of DAC design, then designing one will be a project on its own. \$\endgroup\$ – Bimpelrekkie Jan 23 '19 at 12:36
  • \$\begingroup\$ Replace the resistors in your R-2R ladder with mosfets and you got your DAC. \$\endgroup\$ – Linkyyy Jan 23 '19 at 14:29
You can look into a current steering DAC. It is basically a differential pair (5Pack) amplifier. Razavi has a introductory paper on this in his Circuit for all seasons issue.
This is the IEEE link: https://ieeexplore.ieee.org/document/8275558
This should be the same uploaded on the UCLA website: http://www.seas.ucla.edu/brweb/papers/Journals/BRWinter18DAC.pdf
However, these DACs are very high speed and consume a lot of power even when idle. You may not meet the power budget of your project using this architecture.
| improve this answer | |
Maybe something like this
