this is more of a 'I have no ideas how to route this part' than 'I don't how to technically route this part'. Or maybe both. Basically I have no ideas how to route and what to do here.
R35 cant access those pins which is a big problem. Any ideas?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communitythis is more of a 'I have no ideas how to route this part' than 'I don't how to technically route this part'. Or maybe both. Basically I have no ideas how to route and what to do here.
The way this is typically done is with micro vias (via less than 6 mil in diameter), this will also add manufacturing cost. Compare the manufacturing cost to the cost of the package (if there are different options go with a different package).
You'll need to add another via size in the via template and change the DRC rules if you use them.
Source: https://e2e.ti.com/support/microcontrollers/msp430/f/166/t/649693
