Shown below is the internal block diagram of a switched mode battery charger IC (LT1510). The LT1510 is a current mode, PWM (pulse-width modulated), positive buck switcher that operates in one of two states: constant current or constant voltage.
From the design note enter image description here
Iam having difficulty understanding the operation and internal block diagram of IC (especially the highlighted sections). Kindly excuse my beginner level knowledge on current mode control and op-amp compensation.
  1. Can somebody explain how 'constant voltage- constant current' mode happens here?
  2. The current mode control employed is peak current mode control. In peak current mode control inductor current is sensed ( along with slope compensation) and compared with a control voltage derived from the voltage control loop. What is the purpose of current amplifiers CA1 and CA2 here?
Design note of LT1510
  • CA1 amplifies the sensed voltage drop from the current sense resistor. It is not an Op Amp. The CA indicates it some form of Current Amp.
  • VA is a voltage amp that scales down the battery voltage and amplifies its voltage above the Vref=2.465
  • The two diodes then form an analog OR gate where the higher voltage controls the current rate of charge. Starting in CC mode the diode for the VA is too low.
  • When the VA diode rises above then it enters CV mode and the diode OR output remains at the same voltage.
  • The PROG pin filters the rate of change to make the loop stable from overshoot and ringing.
  • the charger is controlled by a voltage controlled current from the diode OR node such that a rising voltage above CA2+=Vref turns off the battery charger current. -but this current pump is triggered in spurts controlled by a comparator for PWM that regulates the pull-up current driver by regulating the DIODE OR node voltage.
    • is that voltage goes up and down the compared turns the pull up driver Qsw on and off and thus adjusting its duty cycle, according to the state of charge and hence the name PWM.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
