i need to transfer my data using wireless communication, so have opted for Xbee ZigBee from digi international. The idea is to connect 4-20mA output of my sensor directly to the Xbee module's analog pin and this acts as transmitter. at the receiver end, I have another xbee module connected to Arduino which displays data on the serial monitor. will this work? or do i have to consider any other factors. thank you.
  • \$\begingroup\$ Usually your analog pins are voltage inputs. You need a resistor to transform the current into a voltage to read in the value. \$\endgroup\$ – Arsenal Jan 25 at 7:05
