I am trying to understand the difference I am seeing in voltage signals, that I am applying to my circuit's input.
So the basic layout is shown in the diagram, I have a connection, A from my function generator that I split and connects to B the oscilloscope and D my circuit input. I also have a probe from the oscilloscope C, connected to the input for the circuit at D.
What I expected is that the signal measured at both the inputs for the oscilloscope should be the same, as they all connect to the same point in the end D, and are grounded. But what I see is this
The connection from the function generator to the scope displays some oscillation while the probe from C is smoother.
I do not understand why. I am hoping someone could explain what is happening, is there some inductance from the length of the cable between the circuit, function generator and oscilloscope, or possible reflection from the input of the circuit or combination of both that may be causing this?
    \$\begingroup\$ What are you using for the A->B connection? If it's just a length of BNC, impedance mismatch could be a problem. I don't remember all the nuances of it. I'm not sure cable inductance would have that large of an effect, but I'm no expert so that is also a possibility. \$\endgroup\$ – Hearth Jan 25 '19 at 15:59
  • \$\begingroup\$ Exactly what kind of cables are you using for each of these connections? What is the impedance of each cable? What is the input impedance of your oscilloscope? Of your "circuit"? What is the output impedance of the function generator? \$\endgroup\$ – Elliot Alderson Jan 25 '19 at 16:26
  • \$\begingroup\$ How long is your cable? \$\endgroup\$ – Voltage Spike Jan 25 '19 at 16:31
  • \$\begingroup\$ regarding my earlier comment: I thought that said \$10^{-2}\$, not -7. Cable inductance could definitely have that much of an effect if it's a reasonably long cable. \$\endgroup\$ – Hearth Jan 25 '19 at 16:36
  • \$\begingroup\$ A-B is a BNC to BNC connection the cable is 2m, A-D is a BNC-SMA connection 1m, and CD to D is a scope probe. The Function generator is 50 Ohm at the output, and the Oscilloscope is 1 MOhm at both inputs. My understanding is each of the cables is 50 Ohm @ElliotAlderson \$\endgroup\$ – Dave Jan 28 '19 at 11:16
Ignoring the noise, it simply looks like the "B" waveform has a lower bandwidth, i.e. it's been low-pass filtered. The overshoot at the top is pretty typical for a band-limited step response.
The fact that there's oscillations that are visible on B but not on C might simply be the inverse effect, where things like wire inductance simply put a damper on some frequencies.
Since this is a rise time of in the order of 100 ns, we're dealing with frequencies of maybe 30, 50, 70 MHz that are attenuated in one path, but not the other. Honestly, at these frequencies, longer cables with mismatches can already produce resonant circuits, where you get strongly freqeuncy-dependent behaviour.
So:
Make sure all your equipment is impedance matched, that involves cables, connectors, your device, and splitters, as well as the input settings on your scope. Make sure your signal generator is strong enough to drive your circuit, split off some energy for the oscilloscope B input, and also drive the probe.
