I'm trying to run RTC, but there are two problems. 1) It is impossible to write the security key in the WPR register. 2) It is impossible to set the time and date in the TR and DR registers. I tried different methods, but still have not found the answer. Code below.
// Delivered clocks by 32.
RCC->CFGR |= RCC_CFGR_RTCPRE_0 | RCC_CFGR_RTCPRE_1 | RCC_CFGR_RTCPRE_2 | RCC_CFGR_RTCPRE_3 | RCC_CFGR_RTCPRE_4;
// OK
RCC->APB1ENR = RCC_APB1ENR_PWREN;
// Enable Backup. OK
PWR->CR = PWR_CR_DBP;
//OK
RCC->BDCR |= RCC_BDCR_BDRST; // Reset register.
RCC->BDCR &= ~ RCC_BDCR_BDRST;
//Using HSE for RTC. OK.
RCC->BDCR |= RCC_BDCR_RTCEN | RCC_BDCR_RTCSEL_0 | RCC_BDCR_RTCSEL_1;
//Protection key. // NO effect
RTC->WPR = 0xCA;
RTC->WPR = 0x53;
//Init OK
RTC->ISR = RTC_ISR_INIT;
//OK
while (!(RTC->ISR & RTC_ISR_INITF));
//OK
RTC->PRER = 0x7D07D0;
//NO effect
RTC->TR = 0x194000;
//No effect.
RTC->DR = 0x198124;
//OK.
RTC->ISR &=~ RTC_ISR_INIT;
//No effect
RTC->WPR = 0xFF;
  • \$\begingroup\$ I have the ability to communicate with the RTC, but I cannot write values to the TR, DR and WPR registers. \$\endgroup\$ – enumvalue Jan 26 at 6:22
  • \$\begingroup\$ are you able to write to any register? \$\endgroup\$ – jsotola Jan 26 at 8:49
  • \$\begingroup\$ Yes I can write some register. \$\endgroup\$ – enumvalue Jan 26 at 15:33
