I have been reading on 802.11p vs C-V2x, the two technologies for vehicular communications. One disadvantage for C-V2x that is frequently mentioned is that C-V2x needs all the UEs to be time-synced which may not be possible in out-of-coverage areas.
My question is why doesn't 802.11 based technologies need the same time sync ? C-V2x is based on LTE and time-sync is needed for resource scheduling.
802.11 is generally a collision detection/avoidance system with uncoordinated stations.
It simply sacrifices rate by depending on "silent stretches" to coordinate medium access, and by requiring a significant amount of synchronization data to be inserted in the frame.
  • \$\begingroup\$ so in LTE, is it correct to say that there is no concept of collisions as everything is scheduled ? \$\endgroup\$ Commented Jan 26, 2019 at 3:15
