Suppose that a lithium-ion cell having total charge capacity Q=10Ah is discharged at a rate of 1A for 30min. What is the net change in the cell's state of charge (in percent)? Round to the nearest percent.
  • 7
    \$\begingroup\$ Reads too much ltke a homework question to deserve an answer. What have you done so far and where are you stuck? \$\endgroup\$ – Brian Drummond Jan 26 at 11:53
  • \$\begingroup\$ on coursera queston is there.but now i got answer. i was little confuse with signs while solving. \$\endgroup\$ – Mrunal Girame Jan 28 at 5:57
$$\Delta Q = I \Delta T$$ right? You're given
$$ I = 1A \\ \Delta T = 0.5 h \\ \Delta Q = I \Delta T = 0.5 Ah \\ Q_0 = 10 Ah $$
Thus $$Q_0 - \Delta Q = 9.5 Ah$$ You subtract because of implications of the word "discharge". Alternatively you could say that the current I is negative.
  • \$\begingroup\$ yup its -10% . i got it later \$\endgroup\$ – Mrunal Girame Jan 28 at 5:59
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
