I cannot achieve a 2.1 Vrms mentioned in their datasheet (pages 4 and 9). I can only output 1.04Vrms from the 1kHz source. Do I measure it wrong or this is what I should expect? Or maybe I get such measurements because it could possibly be a counterfeit chip?
PCM5102A schematic: enter image description here
Update:
I tried to play different sine wave tone (0 dBFS) generated from Audiocheck and now I can see 1.88 Vrms and 5.64 Vpp when there is no load. Is this something I should expect? I'm playing this sound at the full volume over bluetooth since I use CSRA64215 chip as a source for PCM5102A. I also checked CSRA64215 config and it's output level is already set to max.
    \$\begingroup\$ What's your code, bits, and schematic and test points? \$\endgroup\$ – Erik Friesen Jan 27 '19 at 15:40
    \$\begingroup\$ And the link to the datasheet and page reference? \$\endgroup\$ – Transistor Jan 27 '19 at 16:03
  • \$\begingroup\$ 2.1Vrms is 6Vpp @ 1kohm and you are getting 3Vpp @ ? \$\endgroup\$ – Tony Stewart EE75 Jan 27 '19 at 17:25
  • \$\begingroup\$ @ErikFriesen updated the main post with the schematic. I did those measurements directly from OUTL/OUTR and GND nearby. By the way, what do you mean code & bits? \$\endgroup\$ – user1258202 Jan 27 '19 at 17:26
  • \$\begingroup\$ @Transistor updated the main post with the links and page references. \$\endgroup\$ – user1258202 Jan 27 '19 at 17:27
To be able to measure the full-scale output, you have to input a full-scale sine wave.
I do not know what signal generator app you used, but https://www.audiocheck.net/audiofrequencysignalgenerator_sinetone.php certainly is buggy and does not generate a 0 dB FS waveform.
As far as I can see, https://www.wavtones.com/functiongenerator.php works correctly. (Even a 16-bit file will bring you to within 0.01 % of the limits.)
  • \$\begingroup\$ I got the same measurements even with this generator, but then I tried to generate the sine wave using Audacity and it does this job quite well - now I get 1.58 Vrms @1k and 1.91 Vrms @ 10k. I also monitored what the bluetooth module is outputting - for some reason it outputs -0.95dBFS, I checked everything in DSP chain and everything was already bypassed. But I think we can calculate Vrms like that: -0.95dBFS is 0.896396, so 1.91 Vrms @ 10k / 0.896396 = 2.13V. Is it correct? \$\endgroup\$ – user1258202 Jan 29 '19 at 21:08
  • \$\begingroup\$ Yes, -0.95 dbFS is about 89.6 % of full scale. \$\endgroup\$ – CL. Jan 30 '19 at 7:28
