My ESP8266-01 recognises the sensor TSL2561, but the readings always output 65535 for some weird reason. But as I said, when I run the I2C scanner and plug in the wire I see the sensor popping up at 0x39.
When I hook up the same sensor to an ESP8266 NodeMCU breakout and flash the same code on there it reads it out just fine. I have the wires connected as shown below without any resistors or anything in between.
| ESP8266-01 | TSL25611   |
| VCC (3.3V) | VCC (3.3V) |
| GND        | GND        |
| GPIO2      | SCL        |
| GPIO0      | SDA        |
I'm not sure what I'm doing wrong though.
My code:
#include <Wire.h>
#include <ESP8266WebServer.h>
#include <TSL2561.h>
const char *ssid = "Wouter's Place";
const char *password = "";
ESP8266WebServer server(80);
TSL2561 tsl2561(TSL2561_ADDR_FLOAT);
void handleRoot() {
  // Read illuminance
  float visible = tsl2561.getLuminosity(TSL2561_VISIBLE);
  float full = tsl2561.getLuminosity(TSL2561_FULLSPECTRUM);
  float ir = tsl2561.getLuminosity(TSL2561_INFRARED);
  String response = "";
  response += "{\"illuminance\":{";
  response += "\"visible\":";
  response += visible;
  response += ",\"full\":";
  response += full;
  response += ",\"ir\":";
  response += ir;
  response += "}";
  response += "}";
  server.send(200, "application/json", response);
void setup(void)
  Wire.begin(0, 2);
  Serial.begin(9600);
  Serial.println();
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  Serial.print("Connecting to: ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    delay(250);
    Serial.print(".");
  Serial.println();
  Serial.print("Connected to wifi, ip: ");
  Serial.println(WiFi.localIP());
  Serial.println("Setting up TSL2561..");
  if (!tsl2561.begin())
    Serial.println("Could not find TSL2561 sensor, check wiring!");
    while (1);
  Serial.println("Starting server..");
  server.on("/", handleRoot);
  server.begin();
  Serial.println("Web server running!");
void loop()
  server.handleClient();
Resulting output:
  "illuminance":
    "visible": 0,
    "full": 65535
    "ir": 65535
  • \$\begingroup\$ Can you post a schematic? I can't tell what you've hooked up in your video. \$\endgroup\$ – KingDuken Jan 28 '19 at 19:59
  • \$\begingroup\$ please post the code, not a link to the code \$\endgroup\$ – jsotola Jan 28 '19 at 20:06
  • \$\begingroup\$ Just to comment 65536 is 16 bits of all ones. Since the I2C data line idles high, this probably means the slave isn’t responding. \$\endgroup\$ – DoxyLover Jan 29 '19 at 0:16
  • \$\begingroup\$ @DoxyLover thanks, after reading above I started thinking about it and went another time through my code only to find a quite obvious bug. \$\endgroup\$ – wouterds Jan 30 '19 at 15:14
Found the bug after thinking a bit about what @DoxyLover mentioned! Those 2 lines of leftover code shouldn't be here. Apparently the default LED on the ESP-01 is GPIO2 (which is one of the I2C pins I'm using).
