I got the following problem. I would like to prove the the output voltage \$U_{aus}\$ of the following system.
enter image description here I only want to prove it by using currents. So I don't want to use the formula for a voltage divider.
I know I can simplify it to the following system if I want to prove it by using the voltage divider formula.
enter image description here But how do I simplify this system if I only want to use the currents. I know I need a node for that where all currents go in or out. But in the following simplification I got 3 nodes.
Redraw the schematic in a slightly less confusing way:
Start at the bottom:
R5 and R6 have the same voltage across them, and have the same resistance so will share the current equally (or if you prefer, they behave like a single resistor of resistance R). Calling the sum of the currents through R5 and R6, I, we have
V1 = I × R
Next consider R4: The current flowing out of the bottom of R4, must be the same as the current flowing into R5 and R6, which is just I.
V2 = V1 + I × R
Next consider R2 and (R1+R3). That same current, I, must be split between them. You know the voltage across R2 (of resistance 2R) is the same as the sum of the voltages across R1 and R3 (of combined resistance 3R)
using ohms law you know 2R × I_R2 = V_R2 = V_R1 + V_R3 = 2R × I_R1 + R × I_R3 = 3R × I_R3 (since the current through R1 and R3 is the same)
2 I_R2 = 3 I_R3
You also know that I_R2 + I_R3 = I (since the current flowing out the bottom of R3 and R2, can only flow into R4)
Solving those two equations you get
I_R2 = 3/5 I
I_R3 = 2/5 I
So you now know the voltage cross R2 is now 2R × 2/5 I.
which gives
V0 = V2 + 2R × 3/5 I = V1 + I × R + 2R × 3/5 I = I × R + I × R + 2R × 3/5 I = (2+6/5) × I × R = (16/5) × I × R
and
Vout = V2 + R × 2/5 I = V1 + I × R + R × 2/5 I = I × R + I × R + R × 2/5 I = (12/5) x I × R
combining these gives
Vout = (12/5)/(16/5) V0 = (3/4) V0
  • \$\begingroup\$ Thanks for your answer. Almost everything is clear. Could you please explain how you combined Vout and V0 to get the final result? This step is still unclear. \$\endgroup\$ – Nick Jan 29 '19 at 17:32
  • \$\begingroup\$ V0=(16/5) × I × R, therefore I × R=(5/16) V0, substitute that into Vout=(12/5) × I × R to get Vout=(12/5) × (5/16) V0 \$\endgroup\$ – james Jan 30 '19 at 11:33
