i am using ADuCM350EBZ evaluation board,i want to enable UART interrupt, like when i enter any button from keyboard then interrupt will occur. i am using one example given in this board here uart is already initialized like this
/* Initialize the UART, set the baud rate and enable */
ADI_UART_RESULT_TYPE uart_Init (void) {
    ADI_UART_RESULT_TYPE    result = ADI_UART_SUCCESS;
    /* Open UART in blocking, non-intrrpt mode by supplying no internal buffs */
    if (ADI_UART_SUCCESS != (result = adi_UART_Init(ADI_UART_DEVID_0, &hUartDevice, NULL)))
        return result;
    /* Set UART baud rate to 115200 */
    if (ADI_UART_SUCCESS != (result = adi_UART_SetBaudRate(hUartDevice, ADI_UART_BAUD_115200)))
        return result;
    /* Enable UART */
    if (ADI_UART_SUCCESS != (result = adi_UART_Enable(hUartDevice,true)))
        return result;
    return result;
i do not want to change my baud rate how can i enable the UART interrupt i am also uploading my UART.c and UART.h file respectively that will help you for understanding
UART.c
UART.h
Please guide me how can i enable UART interrupt i will be very thankful to you.
  • \$\begingroup\$ Haven't checked your attachments but it should have something like ADI_ENABLE_INT \$\endgroup\$ – Swanand Jan 29 at 15:06
  • \$\begingroup\$ There is a function like this adi_UART_SetInterruptMode(hUartDevice,true); but when initialize UART in interrupt by using this command then i can not see any thing on UART terminal. And when i enter any value from keyboard the pointer disappeared from my code \$\endgroup\$ – Ati Jan 30 at 6:38
