Sorry to trouble you all with a similar question. But this is a different question altogether regarding calculation of voltage difference. I am using NCV3063 IC.
According to my design of the boost converter in my board, I am measuring the values of pin1 and pin2 in multimeter and scope respectively. This is a reference board.
For Vin(Vcc) of 16V, The voltage at pin1(SWC) of the IC is 5.05V as measured in DMM.
  1. Pin2 (SWE), I am measuring in scope, I am getting a peak-peak of some 15.8V with 30.6% duty and max amplitude of 13.8V.
  2. Now, Vswce=difference between the pins 1 and 2.
How to calculate the voltage difference between (1) and(2)?
Or in general, how to calculate the voltage difference between a switching Vout pin (here, pin2) and a constant Vout pin (here, pin1).
Please help
Thanks
    \$\begingroup\$ You should include the schematic of your boost converter. \$\endgroup\$ Jan 29 '19 at 14:33
  • \$\begingroup\$ As pointed out in comments provide a schematic this can probably be taken from the IC data sheet or application note. Also provide links to the data sheet and if applicable application note. \$\endgroup\$ Jan 29 '19 at 15:17
From Spec
VSWCE(DROP) Darlington Switch Collector to Emitter Voltage Drop
(ISW = 1.0 A, Pin 2 to GND, TJ = 25°C)
1.0Vtyp 1.3 Vmax
Note 7. Low duty cycle pulse techniques are used during test to maintain junction temperature as close to ambient temperature as possible
This implies Rce= 300 mohms + 0.8V of Vbe or using linear regression,
Vce= 0.8 + Ic * 0.3Ω
