I just picked up two of these DC motor controllers (https://www.amazon.ca/Controller-Yeeco-Universal-0-01-1000W-Generator/dp/B00RZ97DDQ/ref=sr_1_10?dd=1QzB1w0bE3cxmYrmXew-NA%2C%2C&ie=UTF8&qid=1548387512&sr=8-10&keywords=dc%20motor%20controller&refinements=p_90%3A11828088011).
which indicated in the title a "Reverse". Unfortunately it now seems that this was cut off text, only referring to the reverse polarity protection. Is there any way to hack this device to get bi-directional performance?
Unfortunately I don't have a datasheet, but I assume most of these devices operate in a similar manner. Is there any way to proceed?
You will not be able to make this unit, itself, become bi-directional. You can, however, add a component like a DPDT relay to swap the outputs to the motor.
  • \$\begingroup\$ This should just be comment..... \$\endgroup\$ – Jack Creasey Jan 30 at 0:48
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
