I have an FreeRTOS example running on STM32F429I-DISCOVERY / NUCLEO-F429ZI, which has the STM32F429ZITx MCU inside. But I wish to port this to a new MCU (STM32F429VITx). How do I do it?
The main difference between the two MCUs is:
  • ZITx version has more IOs (LQFP144). VITx is LQFT100
I understand the HAL libraries will be the same (won't they?). Just the pin configs will change. Am I right?
  • \$\begingroup\$ Asked this question on ST-Community too. I was told since both the MCUs have the same CPU chip, just the pinouts will change. \$\endgroup\$ – clmno Jan 30 '19 at 12:24
  • \$\begingroup\$ Look at memory sizes too, not just program flash but also RAM, particularly make sure your initial stack pointer traditionally at the top of RAM is in a location which actually exists on the target . \$\endgroup\$ – Chris Stratton Jan 30 '19 at 15:19
Difference between ZI and VI is only the physical LQFP package size (Z/V), the memory sizes are identical (I/I). The code will be identical and does not care about the physical package.
