-1
TLDR; A computer and monitor works at site A, but the exact same setup fails at site B - the only difference is the power sockets used.
I have a HDMI over ethernet box which allows me to use Cat6 cable to carry a video feed to a remote monitor.
At site A, I connected the below components, and it worked.
Desktop PC > HDMI cable > HDMI Sender > Cat6 cable > HDMI Reciever > HDMI to VGA cable > Monitor.
The PC, Sender, Reciever and Monitor are powered with UK plugs.
However, if I move the exact same components to site B, the system does not work (no monitor output).
Site B has several other systems working OK (computers, monitors etc..), and has never had any power related problems before. The PC works fine at Site B, and detects that it has a monitor connected. The Monitor works at site B when plugged in directly.
Is it plausible that the building's power at Site B is faulty in a way that allows everything to work excepting these HDMI to IP extender boxes?
  • \$\begingroup\$ Another possibility is that the box you purchased is faulty or just not well designed. Did you read the reviews before you bought it? \$\endgroup\$ – Elliot Alderson Jan 30 at 12:48
  • \$\begingroup\$ @ElliotAlderson It works reliably at site A, including when wiggling the cables (to check if they're positional) and power cycling the whole thing a few times. So that makes me want to rule out the box being faulty. \$\endgroup\$ – Jethro Jan 30 at 12:49
    \$\begingroup\$ Site B may have a lot of EMI from other equipment. \$\endgroup\$ – Andy aka Jan 30 at 12:55
    \$\begingroup\$ At site B, run all the equipment from the same filtered power-strip. \$\endgroup\$ – analogsystemsrf Jan 30 at 13:07
    \$\begingroup\$ Don't assume that faulty means non-functional. Faulty can mean that a solder joint failed, making the built-in EMI filter less effective than designed. The reviews on the vendor site suggest you are not the only person to have problems with this device. \$\endgroup\$ – Elliot Alderson Jan 30 at 13:39
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
