I have a current source that can output different types of waveform depending on the input, including DC (Howland current pump). I need to find a solution as to make sure that when DC is not required it does not appear at the output.
Basically here a series capacitor with the output of the circuit could give me that. It would allow to pass every waveform except for the DC one (when I need DC I could decouple that capacitor).
The problem is that when I attach a resistor as being load my signals could be damaged.
I use 1 Hz frequency, amplitudes from 1 V to let's say 50 Volts with mono and bipolar signals, saw-tooth, triangular signals.
Do you think it helps to place a buffer between the capacitor and the resistor?enter image description here
This would look like a high pass filter, with cutoff at 1Hz.
Later edit
  • \$\begingroup\$ Is R1 part of your circuit or is R1 "the load"? \$\endgroup\$ – Elliot Alderson Jan 30 at 15:09
  • \$\begingroup\$ Hi, R1 is the load, I need to have a certain current across R1. V1 stands for the current pump's output and I placed the series capacitor to get rid of DC. \$\endgroup\$ – Roadrunner Jan 30 at 15:11
  • \$\begingroup\$ So are you asking for a unity-gain current buffer rather than something like a voltage follower? You want the current out of the buffer to be the same as the current in, regardless of voltage? \$\endgroup\$ – Elliot Alderson Jan 30 at 15:15
  • \$\begingroup\$ I want to have the current i programmed through my current pump across R1 regardless of this safety measure of getting rid of DC component. I was thinking at the high input impedance of an opamp, that's why the buffer \$\endgroup\$ – Roadrunner Jan 30 at 15:18
  • \$\begingroup\$ I just add a pic with my solution, I do not know whether is going to work. \$\endgroup\$ – Roadrunner Jan 30 at 15:27
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
