During my master thesis, I need to install an old vacuum pump to an machine (1999).
However I encountered this type of connector, which I am not familiar with. I have searched around the web with no results. Due to the weight and placement of the pump in a cleanroom, replacing this connector with another is a last resort.
I would be really glad if you could help me identify this type of connector. The diameter of these pins is approximately 1.5mm while I measured a length of 7.5mm.
The width of the inside is 11mm while the height is 6mm.
Thank you for your help!
photo of connector
  • \$\begingroup\$ Looks like two bare pins in custom enclosure. Measure them and find some matching socket pins. \$\endgroup\$ – Eugene Sh. Jan 30 '19 at 21:14
    \$\begingroup\$ Can you post another picture? The pins aren't in focus, and I can't tell if they are flared or straight... \$\endgroup\$ – bitsmack Jan 30 '19 at 21:21
  • \$\begingroup\$ Start searching but don't hold your breath. digikey.com/en/resources/connectors/index \$\endgroup\$ – EasyOhm Jan 30 '19 at 21:21
    \$\begingroup\$ your fingers are in focus .... unless you are asking a question about your fingers, post another picture? \$\endgroup\$ – jsotola Jan 30 '19 at 21:31
  • \$\begingroup\$ could be XT90 perhaps? \$\endgroup\$ – Jasen Jan 31 '19 at 0:51
This appears to be a Souriau connector SMS2P1 (Note that is the part number for the housing the pins are seperate).
| improve this answer | |
