The ripple of the charging current is pretty important for the aging of an electric battery. So, the current ripple should be as less as possible. In order to reduce the current ripple, we have to use bigger values of inductances (For instance in a boost converter). So, there is a takeover between current ripple and the value of L.
I would like to ask about the maximum value of the current ripple (DI %) that it is chosen in a real application (such as Electric vehicle battery charger). A value of 2.5% current ripple is acceptable?
  • \$\begingroup\$ What sort of battery? Lead acid actually does better with pulse charging. \$\endgroup\$ – Indraneel Feb 1 at 11:44
  • \$\begingroup\$ @Indraneel I am currently studying Li-ion batteries. The charging algorithm that I use is CC/CV \$\endgroup\$ – Yiannis S. Feb 1 at 11:53
  • \$\begingroup\$ What does the battery's datasheet have to say about ripple current? \$\endgroup\$ – Elliot Alderson Feb 1 at 13:31
  • \$\begingroup\$ @ElliotAlderson The datasheet doesn't provide any information about the ripple current. \$\endgroup\$ – Yiannis S. Feb 1 at 19:41
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
