https://imgur.com/a/D4sBi3D
I need to get an adapter to connect the plug from the green board, to the plug on the brown board. However, I have no idea what the green board's connector is called, so I can't find the appropriate adapter. Can you lend a hand?
The green board contains tone generators for an electric piano, the signal is then passed though this connector to the brown board, which is the amp. Pins are spaced 2 mm apart
connector part 1 connector part 2
  • \$\begingroup\$ Give us more photos/angles of the connector on the green board. I can't tell what I'm looking at. \$\endgroup\$ – Glenn Willen Feb 5 '19 at 6:18
Its PH series JST Connector 5 pinenter image description here
  • \$\begingroup\$ Many thanks. What about the other connector? \$\endgroup\$ – KnowingIsHalfTheBattle Feb 5 '19 at 13:34
