Most electric motors have a “stall torque” listed and my understanding is that if you limit the output it will “stall”. What actually happens inside the motor that causes it to stall and why does it not just provide the same amount of torque the whole time?
From Comments:
I have no idea what type of motor it is. It is the motor for my VEX Robotics team and published specs can be found at: PDF Link
Is stall torque the maximum possible torque?
    \$\begingroup\$ There's something wrong with your premise. How would you ever start a motor if what you are saying is true? Please edit your question to explain the context, where you learned this and what type of motor (DC, induction, BLDC, etc.). \$\endgroup\$
    – Transistor
    Commented Feb 5, 2019 at 18:33
  • \$\begingroup\$ @Transistor to be honest I have no idea what type of motor it is. It is the motor for my VEX Robotics team and published specs can be found at: content.vexrobotics.com/docs/instructions/… \$\endgroup\$
    – dalearn
    Commented Feb 5, 2019 at 18:37
  • \$\begingroup\$ No "stall speed" on that spec. \$\endgroup\$
    – Eugene Sh.
    Commented Feb 5, 2019 at 18:38
  • \$\begingroup\$ Sorry, I meant stall torque. I’ve been reading too much about aerodynamics lately! \$\endgroup\$
    – dalearn
    Commented Feb 5, 2019 at 18:39
    \$\begingroup\$ Still, your question does not make sense. Stall torque is the torque the motor is delivering when stalled. \$\endgroup\$
    – Eugene Sh.
    Commented Feb 5, 2019 at 18:41
The stall torque for any electric motor is the torque that it delivers when the shaft is prevented from turning. That may also be the maximum possible torque, but the maximum torque for operation more than a very short time is usually much less than the stall torque. Some motors must be electrically limited from developing stall torque even for starting. Limiting torque is generally done by monitoring the motor current and limiting the voltage to keep the current below a set limit while starting.
Nothing inside a motor "causes it to stall." A motor stalls if the torque required to turn the load exceeds the torque-producing capability of the motor.
A motor produces only as much torque as required to turn the load. A motor's torque capability varies with speed as illustrated by its torque vs. speed capability curve. The torque required to turn a load also varies with load as illustrated by the load's torque vs. speed demand or requirement curve. If the motor has adequate torque capability, it operates at the intersection of the two curves. If the motor is adequate for continuous operation of the load, the operating torque does not exceed its continuous torque rating.
The torque vs. speed capability of a motor is determined by the type of motor, the specific design, and the motor-controller or power-source capability. The continuous-torque capability is determined by motor losses, heat-dissipation capability and the temperature limits of its wire and other components.
If you think of a motor as multiple large inductors that are rapidly switching on and off, then you can see why stall current is much higher than rotating current. Whenever each coil is energized, the current essentially climbs until it reaches equilibrium with the source and the magnetic field, so in the case of a stopped motor, the ohms of the stator will mostly determine the stall current.
