The potentiometer of my (Kemo M012 Power Control) is mechanically broken and I would like to replace it.
However, I am unsure whether the replacement needs to meet any specific characteristics or if any off-the-shelf potentiometer (with the same maximum resistance) should suffice.
Is there actually any load going through the potentiometer ?
  • \$\begingroup\$ Potentiometers are usually linear or logarithmic, you would need to know which one you are replacing as well. If it is a rheostat (another name for potentiometer, usually used more often in power applications), there could be quite a bit of load going through it, so it would be best to replace it with one that can handle the same power dissipation. \$\endgroup\$ – Ron Beyer Feb 5 at 20:34
  • \$\begingroup\$ @jfrohnhofen "pot" is the usual vernacular shortening of potentiometer, at least in English-speaking regions. \$\endgroup\$ – Hearth Feb 5 at 22:12
  • \$\begingroup\$ @Hearth - Indeed, but FYI in German at least, it's poti. See here for confirmation. I've changed the text in the question to the full word. \$\endgroup\$ – SamGibson Feb 5 at 23:05
I'm guessing that in that black box is a phase controlled triac, and that the potentiometer needs to withstand full 240VAC and provide safety isolation, so don't use a cheap potentiometer with metal shaft and body.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
