(From Schuam's Outlines Computer Architecture, 2002, page 193, problem 8.7(b))
Suppose I have the following memory hierarchy of:
CPU <-> SRAM <=> DRAM <=> DISK
SRAM has 5 ns access time
DRAM has 60 ns access time
DISK has 7 ms access time.
If the hit rate at each level of memory hierarchy is 80% (Except the last level of DISK which is 100% hit rate), what is the average memory access time from the CPU?
So I start the problem... here are my calculations:
For the DRAM Level the access time is:
$$ T_{DRAM} = (0.8)(60 ns) + (0.2)(7 ms) $$
$$ T_{DRAM} = 1.448 \mu seconds $$
For the SRAM/CPU Level the access time is:
$$ T_{SRAM} = (0.8)(5 ns) + (0.2)(1.448 \mu s) $$
$$ T_{SRAM} = 293.6 ns $$
Now for the problem, the solution manual for the book says the answer is:
$$ T_{SRAM} = (0.80)(5 ns) + (0.20)(0.80)(60 ns) + (0.20)(7 ms) $$
which I calculate to be: 1.4136E-6 seconds and they calculate to be:
$$ T_{SRAM} = 280,0136.6 ns $$
My answer is "293.6 ns", and the book's solution to the problem is "280,0136.6 ns"
Who is right and why?
  • \$\begingroup\$ How many ns are in a ms? ;) \$\endgroup\$
    – marcelm
    Feb 5, 2019 at 23:28
  • \$\begingroup\$ $$1 ms = 10^{-3} sec$$ $$1 \mu s = 10^{-6} sec$$ $$1 ns=10^{-9} sec$$ \$\endgroup\$ Feb 5, 2019 at 23:31
Your formulas look fine to me, but there's an error in the numbers: $$ T_{DRAM} = (0.8)(60 ns) + (0.2)(7 ms) \\ T_{DRAM} = 1.448 \mu s $$ This is incorrect, with \$0.2 * 7\$ ms in the sum, the answer should be at least 1.4 ms, not µs.
Note that 1 ms = 1000 µs = 1 000 000 ns.
Compare:
$$ T_{DRAM} = (0.8)(60 ns) + (0.2)(7000 ns) \\ T_{SRAM} = (0.8)(5 ns) + (0.2)(T_{DRAM}) \\ T_{SRAM} = 293.6 ns $$
with:
$$ T_{DRAM} = (0.8)(60 ns) + (0.2)(7000000 ns) \\ T_{SRAM} = (0.8)(5 ns) + (0.2)(T_{DRAM}) \\ T_{SRAM} = 280013.6 ns $$
If you substitute \$T_{DRAM}\$ in the \$T_{SRAM}\$ expression, you get:
$$ T_{SRAM} = (0.8)(5 ns) + (0.2)(0.8)(60 ns) + (0.2)(0.2)(7000000 ns) $$
The expression you quoted from the book is slightly different (only one \$(0.2)\$ in the last term of the sum). That looks like either an error in the book, or in your quote.
  • \$\begingroup\$ ahh...ok... i see the error... was using 10^-6 instead of 10^-3... thanks for confirm that books equation is wrong... but strangely their answer was right in the end... \$\endgroup\$ Feb 6, 2019 at 0:10
  • \$\begingroup\$ Workings/formulas get copied and pasted. You go back and edit contents. Sometimes you fix all, sometimes you do not. Usually you get the final answer correct. \$\endgroup\$ Feb 6, 2019 at 1:06
  • \$\begingroup\$ @MrCasuality Check my update; if the book actually has \$(0.2)(0.2)\$ in the last term of the sum, the equation in the book is also correct! \$\endgroup\$
    – marcelm
    Feb 6, 2019 at 15:43
  • \$\begingroup\$ typographical error in book... that's what was confusing me. \$\endgroup\$ Feb 8, 2019 at 13:33
