We are using PICkit 2 (STL035V2.0 See here ) to program a PIC 16F676. We got the error :
PICkit 2 VPP voltage level error. Check target & retry operation. Error in PICkit 2.
We also get the error: Invalid OSCCAL Value detected warning.
We just found a solution and would like to post it here.
Actually the PICkit we are using is little different from standard PICkits. We placed the IC at the wrong position on the bed.Ours is a 14 pin IC (PIC 16F676). So It gave the errors
In this PIC kit See here it is quite different, and you can see that we have to place the IC in the 3rd position starting from the top.(For 14 pin IC, 8 Pin IC and 20 Pin IC) . And For the 18 Pin IC, you need to keep it where it is marked as 18.
Refer this Image for Position
So that will solve the first error.
And for the second error,
Just select the following in PICKit Programmer Software:
  1. Select Tools->Check Connection.
  2. Goto Device Family Menu.
  3. Select the correct device family. Ours was Midrange->Standard. (PIC 16F676)
  4. If you are not able to select device manually, check the Programmer menu, and Check "Manual Device Select"
  5. Check if the OSCALL value is not highlighted in Red color.
Pickit 2 Software
Now try reading, blank check, erase,etc.
Note: This is for this version (STL035V2.0) Version only. Check Your Pickit for the placing the IC at the correct position.
    \$\begingroup\$ You found that placing the PIC16F676 in the fourth row works. What passes for documentation image recommends the third row. There is a jumper to select between 24-40 pins DIPs and 8-14-18-20 DIPs. The STL035V2.0 seems a bit of a hazard for PIC device programming. \$\endgroup\$ – Dan1138 Feb 6 at 19:28
  • \$\begingroup\$ Good share Dann, I'll check by placing the controller in that pin and let you know. Can you share the link of your finding? \$\endgroup\$ – Reejesh PK Feb 6 at 19:37
    \$\begingroup\$ @ReejeshPK - I don't know whether Dan1138 found it in the same place as I did, but I found the image he kindly linked on this product's Amazon India page here. See the 5th image down on the left side. (P.S. Dan will have been notified of your comment, as his was the only comment when you replied - but unless you use the "@name" syntax, you may find some people will not get notified - the rules are quite complex. See meta.stackexchange.com/q/43019 for more info.) \$\endgroup\$ – SamGibson Feb 6 at 21:19
  • \$\begingroup\$ @Reejesh PK ,@SamGibson, The link Sam posted is where I found the image. The web site for company that makes the programmer is printed on the board. You will find a lower quality image on that web page as well. \$\endgroup\$ – Dan1138 Feb 7 at 4:52
  • \$\begingroup\$ Thank You @Dan1138 and @ SamGibson. You guys are right. For the 8,14 and 20 PIn we should place it at the thrid row, I tested it by reading, writing and erasing with a PIC16f676 and it works fine with the third row and not with the fourth one. I'll correct my answer. \$\endgroup\$ – Reejesh PK Feb 7 at 13:49
By clicking "Post Your Answer", you agree to our terms of service, privacy policy and cookie policy
