-1
I am converting my cordless drill to corded. to do this I need to use the charger which slides on the battery to attach to the damaged tools sole plate. I made a connection between the drill motor wires and the chargers input port in order to power the motor with the original battery. I have a second identical battery charger. can I remove the charging pcb or bypass it to make a direct connection between the drill motor and the plate contacts. the charging plate will simply replace the tools damaged bottom. in this way I can use the battery as designed or charge battery as designed or a direct connection to the motor from a dc power supply. does this seem possible?
    \$\begingroup\$ Probably not. There's no reason to think that the charger output has the current capacity to operate the motor directly -- or that its "battery charging logic" won't be thoroughly confused by having the motor as a load. \$\endgroup\$ – Dave Tweed Feb 7 at 23:31
  • \$\begingroup\$ Instead, perhaps you should learn to repair the batteries. \$\endgroup\$ – K H Feb 8 at 7:46
No, do not do this. A charger applies current in the range of tens of mA to trickle charge the battery. The motor may draw thousands of mA when its pushing a load. There are other details as to how battery charging works, but your proposal just will not work.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
