I have a project in quartus with many files containing full-path-links to other files.
I found a way to make it work on my machine with a different location, but that is the cheat way.
I would like to change all the paths to be relative, so that other engineers won't have the same problems.
What should I do?
If I change all my "C:\projects\filt..." to relative "..." will I ever get newly generated files with full paths when I continue working with it ?
And what should I do when i create a new quartus project (with nios hw and sw) to make full-path-links never appear anywhere?
For example the filt.elf file:
...filt_NIOSII_SW.c D:\filt\software\filt_NIOSII ...
For example the filt_NIOSII_SW.o file:
... alt_alarm_list D:\filt\software\filt_NIOSII_BSP alt_llist_insert...
For example the libhal_bsp.a file:
... filt_NIOSII_SW.c D:\filt\software\filt_NIOSII signed char ...
    \$\begingroup\$ Could you give a specific example where you have these absolute paths in your files? \$\endgroup\$ – Humpawumpa Feb 8 at 14:28
  • \$\begingroup\$ edited the initial post. Here are some examples. \$\endgroup\$ – RKishmar Feb 11 at 4:52
