I have a project that requires an odd voltage of 15DCV. The power pack that I plan to build will be two 12DCV 7AH SLA batteries with a DC-DC converter.
So I know that my starting conditions will be: Input Volts: 24v Input Capacity: 7AH
DC-DC converter (LM2596): 24DCV to 15DCV
Load: intermittent (6-12 times/day) 15DCV, ~1 amp, ~30sec duration
My question is "How does the DC-DC converter factor into the load calculations to figure out estimated battery life?"
How do I figure in loses from the converter?
Supplemental information: I know that running the same system at a reduced 12DCV results in about a 48hr runtime on a 12v SLA 1.3AH battery.
Thanks for the help!
  • \$\begingroup\$ Consider watt-hours, rather than amp-hours, and think about the efficiency of your buck converter. \$\endgroup\$ – Hearth Feb 8 at 14:18
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
