I'm trying to find the minimum supply voltage for the LF356N op amp. In the "LF35x" line from the datasheet below, that field is left blank. Same goes for the Absolute Max Ratings (not shown here).
I'm looking for an op amp that will continue to function even as batteries wear down, which is why I want to know the minimum supply voltage at which the op amp will still function.
How should I interpret the datasheet?
EDIT: Datasheet link here
