I've been working hard to understand boost converters and the role of inductors in the boost converter circuit. I found a pretty good list of basic calculations from Texas Instruments and I started doing some back of the napkin calculations for the TPS61232.
My logic so far has been to say, roughly:
If I need 5V at 1.2A, that's 6W of output. If I get 80% efficiency I'll need 7.5W of input at 2.8V worst case . . . so I'll be pulling 2.7A from the source.
As I read through that TI document, I noticed that D
and (1 - D)
show up pretty often in these calculations.
So, I computed D for my circuit:
$$ D = 1 - \frac{V_{in(min)} * η }{V_{out}} = 1 - \frac{2.8V * .8}{5V} = .552 $$
Then, I read about computing the ripple current: $$ ΔI_{L} = \frac{V_{in(min)} * D}{f_{s} * L} = \frac{2.8V * .552}{2.0MHz * 1uH} = .7728A $$
The datasheet says the input voltage ripple is ±200 mV and the TI document says you can usually estimate inductor ripple to be 20% - 40% of the output current. My calculation at 1.2A is .7728A which is about 60%; that seems kind of high, but I can't tell that I'm doing something wrong. Maybe it's by design? Maybe it's because they're more optimistic about their 90% efficiency? Or, maybe it's based on their output current rating of 2.1A?
In any case, I wanted to know how much DC current the inductor needed to be rated for at various output currents, so I tried to come up with a formula. I saw that the I(max out)
formula uses ΔI(L)/2
. I assumed that's because the ripple is half above and half below V(in)?
So, I decided that something along these lines is probably pretty close:
$$ I_{L} = \frac{ΔI_{L}}{2} + \frac{V_{out} * I_{out}}{V_{in(min)} * η} $$
As I was factoring I(out)
out, I realized that my formula could be expressed as to:
$$ I_{L} = \frac{ΔI_{L}}{2} + \frac{I_{out}}{1 - D} $$
So, I thought, "hey, there's that duty cycle again. Why does it keep showing up?" What is a duty cycle and why does it seem so important to switch mode power supply circuits?
Based on this formula, I looked at the effects of output current on the inductor current and came up with these:
$$ I_{L} = .3875A + \frac{1.2A}{.448} \approx 3.1A $$ $$ I_{L} = .3875A + \frac{0.75A}{.448} \approx 2.1A $$
Am I even in the ballpark here? If I am, how much should I derate inductors? I mean, if I'm looking for 3.1A in the inductor, should I look for a thermal and saturation DC rating greater than, say, 130% of 3.1A? 200%?
