I am trying to characterize this nmos on Xyce simulator (and trying to change its present Vthreshold) and am first DC sweeping the gate and measuring the current through the nmos.
I run into this strange issue where even if I sweep Vg from 0-1.8V and wire drain/source interchangeably, I find the same current going through the nmos. And it has an unusually high resistance.
Two questions, am I doing wrong with this NMOS? AND, I am using this SPICE 180nm BSIM3 model and cannot find how to change Vthreshold on it. With these models is that generally something one can do?
* NMOS Model 180nm
*********Analysis Commands**************
.DC Vg 0 1.8 0.1
.print DC V(3) I(Vd)
*Power Source
Vd 1 0 1.8V
*NMOS device M<name> <drain node> <gate node> <source node> + <bulk/substrate node> <model name>
M1 0 3 1 0 NMOS180
* sense resistors
;R1 2 0 1k
*Gate voltage
Vg 3 0 0V
*NMOS online model card
.model NMOS180 NMOS(
+Level = 49
+Lint = 4.e-08 Tox = 4.e-09
+Vth0 = 0.3999 Rdsw = 250
+lmin=1.8e-7 lmax=1.8e-7 wmin=1.8e-7 wmax=1.0e-4 TNOM=27.0 version =3.1
+Xj= 6.0000000E-08 Nch= 5.9500000E+17
+lln= 1.0000000 lwn= 1.0000000 wln= 0.00
+wwn= 0.00 ll= 0.00
+lw= 0.00 lwl= 0.00 wint= 0.00
+wl= 0.00 ww= 0.00 wwl= 0.00
+Mobmod= 1 binunit= 2 xl= 0
+xw= 0 binflag= 0
+Dwg= 0.00 Dwb= 0.00
+K1= 0.5613000 K2= 1.0000000E-02
+K3= 0.00 Dvt0= 8.0000000 Dvt1= 0.7500000
+Dvt2= 8.0000000E-03 Dvt0w= 0.00 Dvt1w= 0.00
+Dvt2w= 0.00 Nlx= 1.6500000E-07 W0= 0.00
+K3b= 0.00 Ngate= 5.0000000E+20
+Vsat= 1.3800000E+05 Ua= -7.0000000E-10 Ub= 3.5000000E-18
+Uc= -5.2500000E-11 Prwb= 0.00
+Prwg= 0.00 Wr= 1.0000000 U0= 3.5000000E-02
+A0= 1.1000000 Keta= 4.0000000E-02 A1= 0.00
+A2= 1.0000000 Ags= -1.0000000E-02 B0= 0.00
+B1= 0.00
+Voff= -0.12350000 NFactor= 0.9000000 Cit= 0.00
+Cdsc= 0.00 Cdscb= 0.00 Cdscd= 0.00
+Eta0= 0.2200000 Etab= 0.00 Dsub= 0.8000000
+Pclm= 5.0000000E-02 Pdiblc1= 1.2000000E-02 Pdiblc2= 7.5000000E-03
+Pdiblcb= -1.3500000E-02 Drout= 1.7999999E-02 Pscbe1= 8.6600000E+08
+Pscbe2= 1.0000000E-20 Pvag= -0.2800000 Delta= 1.0000000E-02
+Alpha0= 0.00 Beta0= 30.0000000
+kt1= -0.3700000 kt2= -4.0000000E-02 At= 5.5000000E+04
+Ute= -1.4800000 Ua1= 9.5829000E-10 Ub1= -3.3473000E-19
+Uc1= 0.00 Kt1l= 4.0000000E-09 Prt= 0.00
+Cj= 0.00365 Mj= 0.54 Pb= 0.982
+Cjsw= 7.9E-10 Mjsw= 0.31 Php= 0.841
+Cta= 0 Ctp= 0 Pta= 0
+Ptp= 0 JS=1.50E-08 JSW=2.50E-13
+N=1.0 Xti=3.0 Cgdo=2.786E-10
+Cgso=2.786E-10 Cgbo=0.0E+00 Capmod= 2
+NQSMOD= 0 Elm= 5 Xpart= 1
+Cgsl= 1.6E-10 Cgdl= 1.6E-10 Ckappa= 2.886
+Cf= 1.069e-10 Clc= 0.0000001 Cle= 0.6
+Dlc= 4E-08 Dwc= 0 Vfbcv= -1 )
*****unrecognized parameters ******
;tref -> tnom
;xl -> xl (xyce has but default is zero
;xw -> xw (xyce has but default is zero
;PHP,binflag,N -> hspice specific
;CTA,CTP,PTA,PTP -> not found
;NQSMOD (noin quasi specific model) -> NQSMOD (recommended zero)
And here is the output file that shows current flowing equally in both directions. Both output files show the same current at the same timestep
UPDATE:
I have tried setting the substrate node to ground in this circuit but still get symmetrical source-drain current behavior.
