We want to use µPD6379A in our project. after a lot of search we've found no data (code example or schematic hint) about using it on internet. Can anyone guide us on using that IC. Any advice would be much appreciated.
  • \$\begingroup\$ Wires tend to be good for connecting devices together. For more detailed information, some datasheets would be helpful. \$\endgroup\$ – Hearth Feb 11 at 21:48
    \$\begingroup\$ Why do you want to use a 25 year old part for which you have no data? \$\endgroup\$ – JRE Feb 11 at 21:50
    \$\begingroup\$ That datasheet has an example circuit and a description of the communication protocol and data format. That's probably the best you can expect. \$\endgroup\$ – JRE Feb 11 at 21:52
  • \$\begingroup\$ @Hearth Yes, thanks. I mean detailed connection and some code example \$\endgroup\$ – paradisal programmer Feb 11 at 22:25
  • \$\begingroup\$ @JRE Thank you for the link, I want example of using that. some code example about how to send data to it. (data transmission protocol) \$\endgroup\$ – paradisal programmer Feb 11 at 22:27
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
