Does anyone have a link for the list of all the configurations of BJT and MOSFET which create the logic gates?
Like for NAND gate below:
    \$\begingroup\$ You probably don't want all logic gate configurations, because I am quite sure you can come up with some monumentally bad designs for logic gates. \$\endgroup\$
    – Hearth
    Feb 12, 2019 at 16:11
  • \$\begingroup\$ What would you suggest? \$\endgroup\$
    – user212221
    Feb 12, 2019 at 16:22
  • \$\begingroup\$ The ones actually in use. I was being kind of facetious; I think most people will understand what you want. \$\endgroup\$
    – Hearth
    Feb 12, 2019 at 16:23
  • \$\begingroup\$ Dont understand, can you explain better please? \$\endgroup\$
    – user212221
    Feb 12, 2019 at 16:33
  • \$\begingroup\$ Don't worry about it, evildemonic's answer is a good source for what you want. \$\endgroup\$
    – Hearth
    Feb 12, 2019 at 16:36
I learned these with a book called "TTL Cookbook". It is pretty dated, and uses BJTs. You might search for a "CMOS Cookbook" which will use MOSFETS for the same circuits.
