I have been trying to create a bandpass filter with the cut-off frequency at \$\mathrm{200Hz}\$ and \$\mathrm{4800Hz}\$ I have managed to get the centre frequency to \$\mathrm{2500Hz}\$. The bandwidth on the to be non-existent and I have somehow created a really bad high-pass filter.
Below is the circuit I have created:
I am using a \$\mathrm{40nF}\$ capacitor, \$\mathrm{0.1H}\$ and a \$\mathrm{1718}\Omega\$ resistor in parallel which is all in series with another \$\mathrm{1718\Omega}\$ resistor.
This then creates the AC sweep:
In order to get the values I have I did the following:
I knew that resonant frequency is $$ f_o= \frac{1}{2\pi\sqrt{LC}} $$
I assigned a value to \$L\$ of \$\mathrm{0.1H}\$ and rearranged to get the capacitance
Then for bandwidth: $$ B = R\sqrt{\frac{C}{L}} $$ I knew the values of \$C\$, \$L\$ and the bandwidth (\$\mathrm{2600Hz}\$)
*I realise now that the values of the resistors are incorrect but I have also tried \$\mathrm{1450}\Omega\$ resistors and the same issue
Can anyone please explain to me why this has happened and how to fix it?
